[GRASS-dev] [GRASS GIS] #1887: improve signal to noise ratio in the build logs
trac at osgeo.org
Mon Feb 18 16:10:29 PST 2013
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.4
Component: Compiling | Version: svn-trunk
Keywords: make | Platform: Linux
Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:1887 hamish]:
> what does it mean?
It means that you have multiple rules (with commands) for a single target
(in this case, the "install" target). The last rule defined is used, any
others are ignored.
> if it is benign, can we make it go away without masking any real
problems?
The "install" target in Rules.make recursively runs "make install" for
each directory in $(INSTALL_SUBDIRS). AFAICT, nothing ever sets that
variable, so the target is pointless.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1887#comment:1>
