[GRASS-dev] Additional switch(es) for <g.mapsets>?
Markus Neteler
neteler at osgeo.org
Tue Feb 19 02:25:28 PST 2013
On Mon, Feb 18, 2013 at 11:03 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Mon, Feb 18, 2013 at 10:39 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> On 18 February 2013 20:08, Markus Metz <markus.metz.giswork at gmail.com> wrote:
>>> On Mon, Feb 18, 2013 at 6:51 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>>> Since the -s flag does not add new functionality to g.mapsets, I would
>>> strongly opt to remove the -s flag.
>>> If you want to use the customized gui interface for
>>> r.in.gdal/v.in.ogr/r.colors/v.clean/i.group/g.mapsets etc, use the gui
>>> menu.
>>> Otherwise, you can use the command line.
This makes perfect sense: i.e. g.mapsets fired up from cmd line
without anything pops up the nice related g.mapsets gui window.
>> But still there are some power users which would like to avoid
>> starting the main big GUI. Personally, I like the idea of accessing
>> anything in the gui from command line (one reason is that it helps to
>> reduce dependencies in the gui code).
>> One solution would be run gui for modules such as r.in.gdal by some
>> gui starter command which would accept the module name as a parameter;
>> it is something like command line menu (g.gui.climenu). This was
>> proposed for the g.gui.* in order to avoid having many new modules or
>> to avoid the new kind of modules.
+1
> I am not sure if this needs emphasizing, but the customized GUI
> interfaces already exist. The idea here is to call the already
> existing customized interface for a given module, e.g.
> r.in.gdal/v.in.ogr/r.colors/v.clean/i.group/g.mapsets etc. No funny
> flag needed in the module.
Much agreed :)
markusN
