[GRASS-dev] [GRASS GIS] #1890: wingrass: lauch grass terminal fails
trac at osgeo.org
Tue Feb 19 21:10:11 PST 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: Startup | Version: svn-releasebranch64
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-64 |
when starting grass on a fairly fresh Windows7 install, if you try to
launch the cmd.exe version of the grass terminal from the start menu
("GRASS $ver Command Line) you see a dos box flash up then disappear. If
you try it from an already-running cmd.exe window you see the error at the
DOS prompt:
The system cannot find the batch label specified -aftertextcheck
from then on the %PATH% is updated and many %GRASS_*% enviro variables
exist, but grass hasn't really started up and grass modules will not run.
this is a regression from grass 6.4.2, I suppose some goto: related
tragedy in the .bat file.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1890>
