[GRASS-dev] [GRASS GIS] #1829: Allow user to override MAPSET ownership check
trac at osgeo.org
Wed Feb 20 01:13:52 PST 2013
Reporter: marisn | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: Startup | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by wenzeslaus):
os.environ['GRASS_SKIP_MAPSET_OWNER_CHECK'] = '1'
This works. I've just tried this in Python. It was very helpful, by the
way.
However, I don't know how to support this in GUI.
1) It is env variable not gisenv variable, so it is per-process. GUI
cannot set it for command line. Two solutions:
* set the variable on grass start-up (the safe way, but still, I don't
know how to transfer the wxGUI settings to start-up script)
* change this to gisenv variable (consequences?)
2) Where to put the check in the GUI?
3) Do we even need to support this in GUI (it is a very special thing)?
Can we close this ticket as fixed now?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1829#comment:2>
