#1829: Allow user to override MAPSET ownership check
Reporter: marisn | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: Startup | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by hamish):
(a bit off-topic, but for anyone who didn't know these non-obvious points
already it's worth repeating)
n.b. 1) in GRASS 6 GRASS_ADDON_PATH needs to be set in ~/.bashrc not
~/.grass.bashrc since .grass.bashrc is run last, after the PATH and
everything else is already set up. GRASS_HTML_BROWSER is another in the
same situation, see `grass64 --help` for the full list.
n.b. 2) the script needs to be in the path for g.parser to function
correctly. Compiled C modules don't need to be in the path though.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1829#comment:4>
