[GRASS-dev] [GRASS GIS] #1784: wingrass6.4.3svn: raster3d problems
trac at osgeo.org
Wed Feb 20 08:19:49 PST 2013
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Raster3D | Version: 6.4.3 RCs
Keywords: | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:4 neteler]:
> Please try r55120 in GRASS 7 (may be backported to G6:
lib/g3d/g3dwindowio.c if working)
tested with
System Info
GRASS version: 7.0.svn
GRASS SVN Revision: 55121
Build Date: 2013-02-20
GIS Library Revision: 52468 (2012-07-27)
GDAL/OGR: 1.9.2
PROJ.4: 4.8.0
GEOS: 3.3.6dev
SQLite: 3.7.10
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
r3.info map=precip3d.500z50 at PERMANENT
WARNING: You are using an old raster3d data format, the vertical unit is
undefined. Please use r3.support to define the vertical unit to avoid this
warning.
| Layer: precip3d.500z50 at PERMANENT Date: ??
| Mapset: PERMANENT Login of Creator: ??
| DataBase: C:\grassdata
| Title: ??
| Units: none
| Vertical unit: (null)
| Timestamp: none
| Type of Map: 3d cell Number of Categories: 0
| Data Type: DCELL
| Rows: 510
| Columns: 890
| Depths: 6
| Total Cells: 2723400
| Total size: 6728954 Bytes
| Number of tiles: 7168
| Mean tile size: 938 Bytes
| Tile size in memory: 4096 Bytes
| Number of tiles in x, y and z: 112, 64, 1
| Dimension of a tile in x, y, z: 8, 8, 8
| Projection: x,y (zone 0)
| N: 5530000 S: 5275000 Res: 500
| E: 4631000 W: 4186000 Res: 500
| T: 3000 B: 0 Res: 500
| Range of data: min = 525.45690918 max = 1801.44433594
(Wed Feb 20 17:14:56 2013) Command finished (0 sec)
g.region -p rast3d=precip3d.500z50 at PERMANENT
projection: 0 (x,y)
zone: 0
north: 5530000
south: 5275000
west: 4186000
east: 4631000
nsres: 500
ewres: 500
rows: 510
cols: 890
cells: 453900
(Wed Feb 20 17:16:45 2013) Command finished (0 sec)
seems to work with this revision in G7.
backport?
thanks
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1784#comment:5>
