[GRASS-dev] On (Landsat) imagery naming patterns
Nikos Alexandris nik at nikosalexandris.net
Wed Feb 20 15:02:42 PST 2013
Nikos wrote:
> > This is, of course, what I did/do for now.  I can't
> > change my naming pattern
> > now anyway.   But I think as a long-term
> > goal, the modules should follow
> > homogeneous naming conventions, as much as possible.
Hamish wrote:
> It should be easy to make i.histo.match.py do name cleansing and
> then back to the orginal, internally. It could make a table/
> dictionary of map names vs. img_1, img_2, ... safe column names
> then work with the safe names. Make the program[mer] do the hard
> work, not the end user.. :)
note-to-self: maybe that would be (another) good exercise for me (later, on
March)?
Note, <i.histo.match> itself adds a user-defined suffix which _always_ begins
with a "." :-)
thnx, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130221/7b0d1916/attachment.pgp>
