[GRASS-dev] [GRASS GIS] #335: export floats and doubles with correct precision
trac at osgeo.org
Thu Feb 21 17:51:20 PST 2013
Reporter: hamish | Owner: grass-dev@…
Type: task | Status: new
Priority: critical | Milestone: 6.4.4
Component: Default | Version: svn-develbranch6
Keywords: precision | Platform: All
Cpu: All |
Comment(by hamish):
> > %.15,7g was chosen because it's perfectly reproducible
> No, it is not. %.17,9g is reproducible. See IEEE 754 standard.
I didn't mean reproducible as far as the binary stored value round-trip
was concerned, I meant reproducible as far as getting the same ascii
result on two different hardware platforms.
for example, getting r.md5sum (addon to aid the test_suite) to give the
same (portable) result when checksumming r.out.ascii output when the data
is stored as floating point &/or not strictly real (2.5000000). My
understanding, for what it is, is that the least sig. digits can flicker
depending on the CPU arch, perhaps the compiler, and programming
language's implementation too.
I can't remember which right now, but one of the ogr/gdal/proj4 input
streams was introducing .00000000001 style artifacts, it's probably worth
digging that up as a real-world test case example as
there are probably two classes of this problem with the same symptom: one
to do with GRASS's use of %f and atof() in places, and another to do with
the output of input values which were malformed before they came into
grass.
Another interesting corner-case example to try with this is the earthquake
demo from the grass-promo/tutorials/ svn, where the heavily logarithmic
data scale within a single dataset really stretches what fits well in the
ieee FP model, and so something more linear like magnitude is used to
store it instead of raw extajoules.
> A perfectly valid range of double fp data is e.g. 1.0e-200
> to 1.0e-300, way smaller than GRASS_EPSILON. You do not want to
> corrupt these data.
(see the following post with the `2^1024` example where I corrected myself
about that after seeing how you fixed the error in my earlier attempt to
make sure the color min/max rule was bigger than the data range)
regards,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/335#comment:26>
