[GRASS-dev] [GRASS GIS] #1893: d.vect on re-opening switches to default layer
trac at osgeo.org
Fri Feb 22 00:29:16 PST 2013
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Steps to reproduce:
* add vector layer
* specify layer to draw (i.e. 2 or -1)
* apply & close dialog
* go to layer properties (opens d.vect)
* check layer - it is correct but in second is changed to default one (1
in 6.4)
This is rather annoying as imagine following workflow: add vector map,
select different layer (-1), change color and symbol. Close dialog. Decide
to again change color/symbol. Open properties, change color, click Apply
and KABOOM! Vectors are gone. Every time someone opens vector properties,
he has to remember to set back layer option too.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1893>
