[GRASS-dev] [GRASS GIS] #1683: error message v.db.addcol
trac at osgeo.org
Fri Feb 22 01:39:28 PST 2013
Reporter: jradinger | Owner: hamish
Type: defect | Status: assigned
Priority: major | Milestone: 6.4.3
Component: Shell Scripts | Version: svn-develbranch6
Keywords: v.db.addcol | Platform: All
Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:12 jradinger]:
> sorry for responding so late.
ditto, better a late response than none :)
> How can I clean up my gisenv as I think that might solve the
> problem? Whats the best way? My ADDON_PATH is extremely long
> and repeatedly the same. Furthermore it seems there is a line
> break in gisenv dividing "r" and "adinger...", which is causing
> the problem above.
see comment:5.
MarkusM wrote:
> You could try to manually edit ~/.grass7/rc.
In GRASS 6 the file is ~/.grassrc6, and you should not be in a GRASS
session when you edit it.
I have had another attempt at making v.db.addcol more robust to external
g.gisenv problems in r55162,3. This report should stay open until the
other ~36 scripts that use `eval g.gisenv` but only really need one
variable from it have been checked/fixed. Spaces and other fun chars in
GISDBASE will make eval unhappy.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:15>
