[GRASS-dev] On i.histo.match (Re: On (Landsat) imagery naming patterns)
Nikos Alexandris
nik at nikosalexandris.net
Fri Feb 22 04:24:13 PST 2013
Nikos wrote:
> > Just FYI, results look nice! I even convert back to 0-1.0 via
> > r.mapcalc --o "${HistoMatchedMap} = ${HistoMatchedMap} / 1000.0"
> > ps- I wonder if *10000 is *better* for higher precision?
Hamish wrote:
> depending on the sensor's 8-bitnesss or not, you can probably calculate by
> hand now many significant digits are useful. A little bit extra probably
> doesn't hurt.
> 1 / 2^8 = 0.00390625
- Does this add up (practically a lot?) to the computational cost for "mortal"
machines?
And two more questions on <i.histo.match>:
- is there a reason, besides time, not to make <i.histo.match> understand
floating points?
- the algorithm implemented in <i.histo.match> does take Average pixel
values as reference(s) upon which all computations are based on for the histo-
matched values, right?
--%<--- lines 165 ~ 167 --- --- --- %<---
# calculate new value of pixel_frequency
average = (tot/n_images)
cHist = cHist + int(average)
thnx, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130222/9b9495d3/attachment.pgp>
