[GRASS-dev] [GRASS GIS] #1695: GRASSGIS does not launch
trac at osgeo.org
Fri Feb 22 13:36:14 PST 2013
Reporter: TheloniusMonk | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Default | Version: 6.4.2
Keywords: launch, wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Changes (by hamish):
* keywords: launch => launch, wingrass
Comment:
Replying to [comment:3 spdj]:
> Same here on Windows 7 (64bit!). Using the ProzessMonitor we
> found a missing read access to a DLL.
could you explain the process of doing that?
> Check access rules of:
> * windows/SysWOW64/msvcr71.dll
see also #1428
yesterday when pressing esc-enter I got an application error with
set_data.exe when starting from the DOS command line startup icon on
Windows7, I'm not sure if that's related or something else. (grass seemed
to start ok after ack, anyway)
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1695#comment:4>
