[GRASS-dev] how to sample a series at one location?
Newcomb, Doug doug_newcomb at fws.gov
Fri Feb 22 13:40:36 PST 2013
Soren,
What a great Friday afternoon brain stretch!  Thanks!
Doug
On Fri, Feb 22, 2013 at 4:13 PM, Sören Gebbert <soerengebbert at googlemail.com
> wrote:
> Hi,
> Am 22.02.2013 21:44 schrieb "Newcomb, Doug" <doug_newcomb at fws.gov>:
> > t.create--> t.register--> t.vect.observer.strds   in GRASS7 ?   Looks
> really nifty, could be useful with the Landsat Cube data sets
> http://landsat.usgs.gov/documents/Oct27_29_2009_huang_LST_boston.ppt
> Yes, thats the idea. I totally forgot, I made I short presentation and
> tutorial at the geostat in 2012:
> http://www.geostat-course.org/Topic_Gebbert
> The presentation and the scripts are available there. The
> t.vect.observe.strds example is in part three of the presentation. The cool
> thing is that t.vect.observe.strds uses time stamped attribute tables to
> store the values.
> Best regards
> Soeren
> > Doug
> > On Fri, Feb 22, 2013 at 2:53 PM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
> >> Thanks Doug,
> >> I knew I could do it with a script and v.what.rast.
> >> What I was hoping was that there is a shortcut already usable in GRASS
> modules. Looks like the new temporal GIS tools may be able to do it.
> >> Michael
> >> ______________________________
> >> C. Michael Barton
> >> Director, Center for Social Dynamics & Complexity
> >> Professor of Anthropology, School of Human Evolution & Social Change
> >> Arizona State University
> >> Tempe, AZ  85287-2402
> >> USA
> >> voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
> >> fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
> >> www:  http://csdc.asu.edu, http://shesc.asu.edu
> >> http://www.public.asu.edu/~cmbarton
> >> On Feb 22, 2013, at 12:31 PM, "Newcomb, Doug" <doug_newcomb at fws.gov>
> >>  wrote:
> >>> Michael,
> >>> You could use v.what.rast  in a python script , iterating the raster
> layers with an sqlite database back end.  I think that would go up to 2000
> columns for each point you have.
> >>> Alternatively, you could use a bit of python with gdal.  I was trying
> to do something similar in GRASS, to change the Z value of each point in a
> text LiDAR file, from absolute above sea level to relative the elevation of
> the ground.  For 25.5 billion text points and a Statewide 20 ft elevation
> grid (6.5 ? billion cells) , it was a bit slow using r.what.  So I
> converted the LiDAR data to (7)  3.3 billion point  LAS format files and
> exported the GRASS layer to an Erdas imagine format file and wrote the
> following ugly python script:
> >>> #!/usr/bin/python
> >>> import os,string,glob,re,gdal
> >>> from liblas import file
> >>> from liblas import header
> >>> from liblas import point
> >>> from gdalconst import *
> >>> h=header.Header()
> >>> #enter the LAS point file name
> >>> infile=raw_input("Enter the input lidar data points file: ")
> >>> #Hardcoded edras imagine file, you will have to use an array for the
> different data layer names
> >>> imgfile="/gisdata2/raster/allnc_20ft_el.img"
> >>> #print "suggest /gisdata2/raster for output dir\n"
> >>> inarr=infile.split('.')
> >>> #This sets the LAS output file, substitute your output text file
> instead
> >>> outfil=inarr[0]+"_norm.las"
> >>> #outfil=raw_input("Enter output text file name: ")
> >>> #This part reads the LAS file, if you
> >>> l=file.File(infile,mode='r')
> >>> #Outputs the LAS file
> >>> lout=file.File(outfil,mode='w',header=h)
> >>> # register all of the drivers, hopefully your gdal speaks GRASS
> >>> gdal.AllRegister()
> >>> #opening and closing the image layers might take some time if you are
> reading thousands of images
> >>> ds=gdal.Open(imgfile,GA_ReadOnly)
> >>> if ds is None:
> >>>     print 'Could not open image'
> >>>     sys.exit(1)
> >>> # get image size
> >>> rows = ds.RasterYSize
> >>> cols = ds.RasterXSize
> >>> bands = ds.RasterCount
> >>> # get georeference info, not sure how this would work for GRASS data
> layers
> >>> transform = ds.GetGeoTransform()
> >>> xOrigin = transform[0]
> >>> yOrigin = transformAsArray(xOffset, yOffset, 1, 1)
> >>> pixelWidth = transform[1]
> >>> pixelHeight = transform[5]
> >>> for p in l:
> >>>     x=float(p.x)
> >>>     y=float(p.y)
> >>>     z=float(p.z)
> >>>     # compute pixel offset
> >>>     xOffset = int((x - xOrigin) / pixelWidth)
> >>>     yOffset = int((y - yOrigin) / pixelHeight)
> >>>     band = ds.GetRasterBand(1) # 1-based index 0? 1?
> >>>     data = band.Readr(value) :continue
> >>>     value = data[0,0]
> >>>     #print value,"11","\n"
> >>>     if "nan" in st[3]
> >>>     znorm = z-value
> >>>     #print znorm,"\n"
> >>>     pt=point.Point()
> >>>     pt.x=p.x
> >>>     pt.y=p.y
> >>>     pt.z=znorm
> >>>     lout.write(pt)
> >>> l.close()
> >>> lout.close()
> >>> #25561312019 points in allreturns
> >>> This managed to process everything over a weekend( in 7 parallel
> threads), which was fast enough for me at the time.  Approaching your
> problem , if your data layers are all n GRASS and your version of gdal can
> read GRASS data layers,  I would grab the list of GRASS layers via glob and
> iterate the layers , writing the name of the raster layer and the value of
> the raster layer at the point coordinates out to a text file as you state
> below.
> >>> Hope this helps,
> >>> Doug
> >>> On Fri, Feb 22, 2013 at 1:23 PM, Michael Barton <
> Michael.Barton at asu.edu> wrote:
> >>>> But I want to do it with a time series of hundreds or thousands of
> maps.
> >>>> Michael
> >>>> C. Michael Barton
> >>>> USA
> >>>> On Feb 22, 2013, at 10:53 AM, Markus Neteler <neteler at osgeo.org>
> >>>>  wrote:
> >>>> > On Fri, Feb 22, 2013 at 6:41 PM, Michael Barton <
> >>>> >> Is there tool somewhere, including in the new temporal GIS
> modules, to
> >>>> >> sample the value of a raster series at one cell location? I'd like
> to get
> >>>> >> text something like this for a cell that I specify with xy
> coordinates or a
> >>>> >> cat:
> >>>> >> map1, value 1
> >>>> >> map2, value 2
> >>>> >> map3, value 3
> >>>> >> map4, value 4
> >>>> >> map5, value 5
> >>>> > I do such queries with r.what which accepts multiple input:
> >>>> > http://grass.osgeo.org/grass64/manuals/r.what.html
> >>>> > Markus
> >>>> _______________________________________________
> >>>> grass-dev mailing list
> >>>> grass-dev at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> >>> Doug Newcomb
> >>> USFWS
> >>> Raleigh, NC
> >>> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> >>> The opinions I express are my own and are not representative of the
> official policy of the U.S.Fish and Wildlife Service or Dept. of the
> Interior.   Life is too short for undocumented, proprietary data formats.
> > Doug Newcomb
> > USFWS
> > Raleigh, NC
Doug Newcomb
USFWS
Raleigh, NC
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130222/a720b481/attachment-0001.html>
