[GRASS-dev] [GRASS GIS] #1762: g.extension fails again
GRASS GIS trac at osgeo.org
Sun Feb 24 13:42:35 PST 2013
 Reporter:  cmbarton   |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  6.4.3
Component:  Addons     |     Version:  svn-releasebranch64
 Keywords:             |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
Changes (by cmbarton):
  * component:  Default => Addons
  * priority:  normal => major
  * platform:  Unspecified => MacOSX
  * version:  unspecified => svn-releasebranch64
  * milestone:  7.0.0 => 6.4.3
  * cpu:  Unspecified => OSX/Intel
Comment:
 I just tried g.extension for the first time in awhile in GRASS 6.4.3
 release branch.
 It is broken on the Mac at least. I've seen notices that it is broken on
 Windows. This may be the same problem. But I'm assuming not for the
 moment. Here the error. GRASS_ADDON_PATH is correct. The problem is
 somewhere else. So far, I've tried r.xtent, r.out.kml, and r.prominence. I
 KNOW that r.prominence used to compile under GRASS 6 at least in the past
 couple years. g.extension has always been on the buggy side with the mac.
 But it was working more or less the last time I tried it a year or so
 back.
 Here is the error for r.xtent
 (Sun Feb 24 14:32:13 2013)
 g.extension.py extension=r.xtent operation=add
 WARNING: GRASS_ADDON_PATH has more items, using first defined -
 '/Users/cmbarton/Library/GRASS/6.4/Modules/bin'
 Fetching <r.xtent> from GRASS-Addons SVN (be patient)...
 Compiling...
 /Applications/GRASS/GRASS-6.4.app/Contents/MacOS/include/Mak
 e/Grass.make:423: warning: overriding commands for target `/
 Users/Shared/grassdata/Global_latlon/Spain_sites_SAA2012/.tm
 p/Michaels-MacBook-Air.local/37744.0/r.xtent/bin'
 e/Grass.make:414: warning: ignoring old commands for target
 `/Users/Shared/grassdata/Global_latlon/Spain_sites_SAA2012/.
 tmp/Michaels-MacBook-Air.local/37744.0/r.xtent/bin'
 e/Module.make:25: warning: overriding commands for target
 `install'
 e/Rules.make:99: warning: ignoring old commands for target
 `install'
 at_exit_funcs.c:30:23: error: grass/gis.h: No such file or
 directory
 at_exit_funcs.c:31:27: error: grass/glocale.h: No such file
 or directory
 directory
 or directory
 lipo: can't figure out the architecture type of: /var/folder
 s/65/pp9w7z0d1mj502pj8hhl7vfw0000gn/T//ccw30r7o.out
 make: *** [OBJ.x86_64-apple-darwin12.2.0/at_exit_funcs.o]
 Error 1
 ERROR: Compilation failed, sorry. Please check above error messages.
 (Sun Feb 24 14:32:21 2013) Command finished (8 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1762#comment:2>
