[GRASS-dev] [GRASS GIS] #1606: WXGUI regression - attribute query tool reports "nothing found" when clicking on a vector object
GRASS GIS trac at osgeo.org
Mon Feb 25 01:26:26 PST 2013
  Reporter:  marisn       |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  blocker      |   Milestone:  6.4.3
 Component:  wxGUI        |     Version:  6.4.3 RCs
Resolution:               |    Keywords:  query
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by mlennert):
 Replying to [comment:11 annakrat]:
 > In case there exist layers of vector map which are not connected to db,
 the query output is redirected in command console (r55184). This is the
 easiest solution, other solutions would need more changes which means more
 possible errors.
 Thanks ! It would be great, however, to be able to copy directly from the
 display, instead of having to copy everything to the clipboard, copy that
 to a text editor and then pick out the elements you want. As an example:
 sometimes I just want to identify the coordinates of a place. It would be
 nice to be able to click on it and then directly copy the values for
 easting and northing from the query results window.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1606#comment:12>
