[GRASS-dev] [GRASS GIS] #1270: wingrass: Error in Attribute Table Manager
trac at osgeo.org
Mon Feb 25 12:07:30 PST 2013
Reporter: antonioall | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: wingrass, attribute table manager | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:16 hamish]:
> moreover, using v.db.addcol from the main db -> vect db conns menu to
add a column had this error:
> v.db.addcol --verbose map=copyofbugs2 at user1 columns=someint2 integer
> DBMI-DBF driver error:
> ERROR: Unable to open database <C:/Program Files (x86)/GRASS GIS
6.4.3svn/msys/Users/Hamish/Documents/GIS DataBase/spearfish60/user1/dbf/>
> ERROR: Cannot continue (problem adding column).
tested with
GRASS version: 6.4.3svn
GRASS SVN Revision: 55185
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.9.2
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
v.db.addcol map=myfires at user1 columns=someint2 integer
(Mon Feb 25 21:05:23 2013) Command finished (2 sec)
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:19>
