[GRASS-dev] [GRASS GIS] #1683: error message v.db.addcol
trac at osgeo.org
Mon Feb 25 16:23:18 PST 2013
Reporter: jradinger | Owner: hamish
Type: defect | Status: assigned
Priority: major | Milestone: 6.4.3
Component: Shell Scripts | Version: svn-develbranch6
Keywords: v.db.addcol | Platform: All
Cpu: Unspecified |
Comment(by hamish):
scripts in devbr6 now updated with r55194:55226, but need testing before
backport to the stable branch.
AFAICT the only ones which will actually trigger run-time processing
errors (instead of just the occasional harmless message) on WinGrass w/
spaces in GISDBASE, are:
* r.pack/unpack (already backported)
* r.in.srtm
* db.droptable
* d.rast.leg (bug? try erode.index at spearfish)
* r.in.wms
* i.image.mosaic
* v.in.garmin (doesn't need to be fixed for wingrass as dep req's UNIX)
so those should be tested & then backported for 6.4.3.
the rest can wait until after the freeze and go in for 6.4.4.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:16>
