[GRASS-dev] [GRASS GIS] #1889: wxPy loc'n wiz: don't auto-launch into PERMANENT
GRASS GIS trac at osgeo.org
Tue Feb 26 03:54:42 PST 2013
 Reporter:  hamish           |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  blocker          |   Milestone:  6.4.3
Component:  wxGUI            |     Version:  6.4.3 RCs
 Keywords:  location wizard  |    Platform:  Unspecified
      Cpu:  x86-64           |
Comment(by wenzeslaus):
 In r55231 I added some doc for r55229 but actually, I don't understand the
 issue completely. I know about ticked #1293 and I can see that functions
 G_legal_filename or G_check_input_output_name (file legal_name.c) are used
 only on a few places (according to grep and programming manual). There is
 some check in G_parser function because it is not possible to create map
 with dot or slash but probably G_legal_filename is not used. (There is a
 warning which is reported twice but that is another issue.)
 I've tried to create map with non-latin characters but I'm not able to do
 it. wxGUI fails with some bugs and command line (Bash Shell) does not
 accept my characters and it does some other things instead such as
 cleaning the line.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1889#comment:10>
