[GRASS-dev] [GRASS GIS] #1900: limiting display vector map using cats doesn't work
GRASS GIS trac at osgeo.org
Thu Feb 28 13:08:53 PST 2013
 Reporter:  pvanbosgeo  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  7.0.0
Component:  Vector      |     Version:  svn-trunk
 Keywords:              |    Platform:  Linux
      Cpu:  x86-64      |
 In the d.vector window, under the tab 'selection' there is the option to
 select category values. Presumably entering one or more cats values, only
 those should be displayed. However, entering values does not do anything,
 the whole map is still displayed.
 Also using a SQL statement to limit what is displayed does not work.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1900>
