[GRASS-dev] [GRASS GIS] #1846: Query vector map tool does not work
trac at osgeo.org
Mon Jan 7 01:17:24 PST 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
The query vector/raster map tool on a vector layer does not work. When
clicking on a layer, the rendering bar in the map display window get's
stuck somewhere on 50-75%. Moreover, the mouse cursor keeps on spinning
when hovering over any GRASS window, also after I close the map display
window (I thought it was related to the rendering of the map).
I am working on GRASS 7 r54557 (but it started in a previous revision), on
Ubuntu 12.10, with Python 2.7.3 and wxPython 2.8.12.1. I marked this as a
major problem as this affects a key functionality i.m.h.o.
The command line output when trying to query a vector layer is:
File "/usr/local/grass7/grass-7.0.svn/etc/gui/wxpython/map
disp/mapwindow.py", line 969, in MouseActions
self.OnLeftUp(event)
disp/mapwindow.py", line 1164, in OnLeftUp
self.frame.Query(self.mouse['begin'][0],self.mouse['begin'][
1], layers)
disp/frame.py", line 685, in Query
self.QueryVector(east, north, qdist, posWindow, layers[0])
disp/frame.py", line 837, in QueryVector
self.MapWindow.UpdateMap(render = False, renderVector =
False)
disp/mapwindow.py", line 612, in UpdateMap
self.mapfile = self.Map.Render(force = False, mapWindow =
self.frame)
File "/usr/local/grass7/grass-7.0.svn/etc/gui/wxpython/cor
e/render.py", line 963, in Render
maps, masks, opacities =
self.GetMapsMasksAndOpacities(force, mapWindow, windres)
e/render.py", line 933, in GetMapsMasksAndOpacities
return self._renderLayers(force, guiFrame)
e/render.py", line 901, in _renderLayers
if not layer.Render():
e/render.py", line 148, in Render
ret, msg = self._runCommand(c)
e/render.py", line 192, in _runCommand
**self.cmd[1])
IndexError
list index out of range
Ticket URL: <http://trac.osgeo.org/grass/ticket/1846>
