[GRASS-dev] Tool-tip for removing map layer should state "remove" and not "delete"
Martin Landa
landa.martin at gmail.com
Tue Jan 8 06:58:55 PST 2013
2013/1/8 Nikos Alexandris <nik at nikosalexandris.net>:
> I think the tool-tip for the button that removes a layer from the wxGUI
> (which, if I understand correctly, does not correspond to g.remove) should be
> described as "Remove selected map layer" or alike -- however, the verb
> "delete" should not be used.
> Currently the tool-tip states: "Delete selected map layer".
right, fixed in r54576. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
