[GRASS-dev] d.correlate not working
Rashad M mohammedrashadkm at gmail.com
Sun Jan 13 20:46:48 PST 2013
when a command is issued and if d.mon wx monitor is working it should be
routed in a different way.
I noticed when d.correlate command is issued with wx  montior ON, the
command is not properly parsed.
could you tell when a command is issued within grass shell with Gui ON,
where is get parsed?
so that i could try for a patch :)
On Mon, Jan 14, 2013 at 10:04 AM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> it worked using command layer
> There should be some an option to use d.correlate in the other way too
> d.mon wx0
> d.correlate .....
> On Sun, Jan 13, 2013 at 9:49 PM, Anna Kratochvílová <kratochanna at gmail.com
> > wrote:
>> On Sat, Jan 12, 2013 at 10:43 AM, Rashad M <mohammedrashadkm at gmail.com>
>> wrote:
>> > using:
>> > grass  7.0
>> > revision:54601
>> > d.correlate is not working
>> > To reproduce
>> > d.mon wx0
>> > d.correlate map=lsat5_1987_10,lsat5_1987_20
>> > error:
>> > GRASS_INFO_WARNING(25298,1): Illegal filename
>> > <landsat,lsat5_1987_20 at landsat>. Character <,> not allowed.
>> > GRASS_INFO_END(25298,1)
>> > GRASS_INFO_WARNING(25314,1): Illegal filename
>> > GRASS_INFO_END(25314,1)
>> > Traceback (most recent call last):
>> >   File
>> "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_misc.py",
>> > line 1358, in Notify
>> >     self.notify()
>> >   File "/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/main.py", line
>> > 290, in watcher
>> >     self.mapFrm.GetMap().GetLayersFromCmdFile()
>> > 102, in GetLayersFromCmdFile
>> >     self.AddLayer(ltype = ltype, command = cmd, active = False, name =
>> name)
>> >   File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py", line
>> > 1042, in AddLayer
>> >     active = active, hidden = hidden, opacity = opacity)
>> 339,
>> > in __init__
>> >     active, hidden, opacity)
>> 88,
>> > in __init__
>> >     self.SetType(ltype)
>> 268,
>> > in SetType
>> >     raise GException(_("Unsupported map layer type '%s'") % ltype)
>> > core.gcmd.GException: Unsupported map layer type 'None'
>> Some of d. commands are not supported yet in wxGUI but at least you
>> can try to add them as a command layer in Layer Manager, it is in the
>> 'Add grid or vector overlays' (perhaps it should be 'Add miscellaneous
>> overlays').
>> Anna
>> > Regards,
>> >    Rashad
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130114/9061328e/attachment.html>
