[GRASS-dev] Strange import of .asc
Helmut Kudrnovsky
hellik at web.de
Mon Jan 14 06:51:53 PST 2013
Hi Paolo,
>Importing an .asc file (with -o) results in a raster which is not aligend
with the
>original.
>Anyone confirms?
gdalinfo 23B07.asc
Driver: AAIGrid/Arc/Info ASCII Grid
Files: 23B07.asc
Size is 1640, 1240
Coordinate System is `'
Origin = (1568780.000000000000000,4896020.000000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Metadata:
AREA_OR_POINT=Point
Corner Coordinates:
Upper Left ( 1568780.000, 4896020.000)
Lower Left ( 1568780.000, 4894780.000)
Upper Right ( 1570420.000, 4896020.000)
Lower Right ( 1570420.000, 4894780.000)
Center ( 1569600.000, 4895400.000)
Band 1 Block=1640x1 Type=Float32, ColorInterp=Undefined
NoData Value=-9999
and
r.info map=testimport at user1
| Layer: testimport at user1 Date: Mon Jan 14 15:45:08 2013
| Mapset: user1 Login of Creator: myricaria
| DataBase: C:\dl\gl\cavallini
| Title: ( testimport )
| Timestamp: none
| Type of Map: raster Number of Categories: 255
| Data Type: FCELL
| Rows: 1240
| Columns: 1640
| Total Cells: 2033600
| Projection: Transverse Mercator
| N: 4896020 S: 4894780 Res: 1
| E: 1570420 W: 1568780 Res: 1
| Range of data: min = 76.581 max = 214.843
| Data Description:
| generated by r.in.gdal
| Comments:
| r.in.gdal -o input="C:\dl\gl\cavallini\23B07.asc" output="testimport"
the extent seems to be the same?
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/Strange-import-of-asc-tp5027341p5027346.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
