[GRASS-dev] [GRASS GIS] #1856: wxGUI with LANG=pl_PL.utf8 throws "'ascii' codec can't decode byte"
GRASS GIS trac at osgeo.org
Sun Jan 20 11:20:20 PST 2013
 Reporter:  msieczka      |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  normal        |   Milestone:  6.4.3
Component:  wxGUI         |     Version:  svn-releasebranch64
 Keywords:  LANG, locale  |    Platform:  Linux
      Cpu:  x86-64        |
 GRASS SVN releasebranch_64 r54578.
 Steps to reproduce:
 1. Set your LANG to pl_PL.utf8:
 $ locale | grep LANG
 LANG=pl_PL.utf8
 2. Run GRASS in wxGUI mode.
 3. Add any vector map (eg. spearfish60/bugsites) to Map Layers.
 4. Right click the vector map in Map Layers > Metadata = error:
   File "/opt/grass64-svn/etc/wxpython/gui_core/goutput.py",
 line 749, in OnCmdOutput
 self.cmdOutput.AddTextWrapped(message, wrap = None)
 line 1228, in AddTextWrapped
 txt = EncodeString(txt)
   File "/opt/grass64-svn/etc/wxpython/core/gcmd.py", line
 103, in EncodeString
 return string.encode(enc)
   File "/usr/lib/python2.7/encodings/iso8859_2.py", line 12,
 in encode
 return codecs.charmap_encode(input,errors,encoding_table)
 UnicodeDecodeError
 'ascii' codec can't decode byte 0xb3 in position 7: ordinal
 not in range(128)
 in encode
 UnicodeDecodeError
 'ascii' codec can't decode byte 0xf3 in position 14: ordinal
 not in range(128)
 (Sun Jan 20 19:46:39 2013) Polecenie zakończone (0 sec)
 Python version used:
 GRASS 6.4.3svn (spearfish60):~ > python --version
 Python 2.7.3
Ticket URL: <http://trac.osgeo.org/grass/ticket/1856>
