[GRASS-dev] [GRASS GIS] #1858: inconsistancy g.parser on command console and command line
trac at osgeo.org
Tue Jan 22 03:25:43 PST 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Shell Scripts | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: Unspecified |
If you have a script r.test with amongst others the following in the
header:
#%flag
#% key: s
#% description: run r.report on output map?
#% answer : 1
#%END
Opening the GUI interface via the command line will show the flag S unset.
Opening the GUI interface via the command console in the GRASS GIS layer
manager shows the flag S as set (see attached screenshot for
clarification)
Running GRASS 7.0 on Ubuntu 12.10
Ticket URL: <http://trac.osgeo.org/grass/ticket/1858>
