[GRASS-dev] About the "-g" switch of g.region
Nikos Alexandris nik at nikosalexandris.net
Tue Jan 22 11:33:28 PST 2013
Nikos Alexandris wrote:
> > Is there a reason why the output of  "g.region -cg" (in decimal degrees)
> > is not the same as the output of "g.region -c" (in D:M:S)?
> > The -g switch is there to "print in shell script style". Does the
> > switch/description imply, necessarily, decimal degrees?
Glynn Clements wrote:
> I think it implies that the output is in a format amenable to use by
> shell scripts.
> DNS is primarily meant for humans; programs which aren't specifically
> designed for geography or cartography won't understand DMS, so it will
> have to be converted, and doing that in a shell script is messy (expr
> and $((...)) only support integer arithmetic).
For the records, I require(d) a bunch of Landsat scene center coordinates.
Yes, in decimal degrees to feed the i.atcorr module. But, it took me a while,
to find it (-g). I was sure I have "grepped" decimal degrees from a grass-
module before -- couldn't recall, however, which one.
Personally a I would prefer a (slightly) different description for the switch,
or, at the very least, some additional note in the manual.
Thank you Glynn, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130122/a6ffde49/attachment.pgp>
