[GRASS-dev] [GRASS GIS] #1859: d.mon is broken
GRASS GIS trac at osgeo.org
Tue Jan 22 13:54:01 PST 2013
 Reporter:  huhabla     |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  critical    |   Milestone:  7.0.0
Component:  Display     |     Version:  svn-trunk
 Keywords:  d.mon, wx0  |    Platform:  Linux
      Cpu:  x86-64      |
Comment(by wenzeslaus):
 Replying to [comment:2 huhabla]:
 > Besides the fact that it is not working for me on two different Ubuntu
 12.04 machines
 I don't understand what is your configuration. The error means that you
 don't have NVIZ.
 > is this part of code bad style:
 > gui/wxpython/mapdisp/toolbars.py line 82 - 91
 > What happens in case there is no parent with a layer manager? In this
 case the application crashes! This exception should be handled, for
 example to use a
 > different log window or the console log?
 You are completely right! This is subject to ongoing refactoring
 (currently paused). This will be fixed, probably, in next days. (Anna will
 provide fix for now.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1859#comment:3>
