[GRASS-dev] Script for converting degrees clockwise from North to GRASS convention
Moritz Lennert
mlennert at club.worldonline.be
Wed Jan 23 05:54:48 PST 2013
On 23/01/13 13:59, Margherita Di Leo wrote:
> Hi Moritz,
> thank you for your reply,
> On Wed, Jan 23, 2013 at 12:21 PM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> If we call WIND the direction map which uses the convention degrees
> clockwise from North, and GRASS the output map, the rule that I
> applied is:
> IF 0 <= WIND < 270 ; GRASS = 270 - WIND
> IF WIND = 270 ; GRASS = 360
> IF 270 < WIND < 360 ; GRASS 630 - 0
> IF WIND = null ; GRASS = 0
> NULL otherwise (this latter I have added to check if there is
> any error.
> This is not correct.
> WIND = 0 means North.
> Actually this was tricky also for me, but:
> Wind direction is measured in:
> degrees clockwise from uphill (direction the wind is pushing the fire)
> degrees clockwise from North (direction the wind is blowing from)
> If the wind is blowing FROM north, it means that the arrow is TOWARDS
> south.. Am I wrong?
I guess not, but this is a very specific application of angle direction.
I think that if you want to create a generic module (r.convert.aspect or
r.convert.angle) for transforming angles, then North should mean North.
If for a specific application North means a direction a force is coming
from, then the use should take that into account. In your case the
original map gives the angle the wind is coming _from_, then the output
should (IMHO) do the same.
Moritz
