[GRASS-dev] [GRASS GIS] #1861: v.net.distance should exclude path to self
GRASS GIS trac at osgeo.org
Thu Jan 24 01:06:53 PST 2013
 Reporter:  mlennert          |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  Vector            |     Version:  svn-trunk
 Keywords:  network distance  |    Platform:  Unspecified
      Cpu:  Unspecified       |
 When using v.net.distance in grass7, giving it all the available nodes as
 from and to nodes, the result is a series of zero length paths from each
 node to itself. v.net.distance should skip paths to self and chose the
 closest node amongst the remaining set of nodes.
 To reproduce:
 v.net roadsmajor points=schools_wake op=connect thresh=500 out=network --o
 ["thresh" should probably be renamed to "threshold" for consistency]
 v.net.distance network out=paths from_layer=2 from_cats=1-999 to_layer=2
 to_cats=1-999 --o
 [from_layer and to_layer should probably be 2 by default]
 v.db.select paths
 cat|tcat|dist
 7|7|0
 8|8|0
 9|9|0
 28|28|0
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1861>
