[GRASS-dev] [GRASS GIS] #1861: v.net.distance should exclude path to self
GRASS GIS trac at osgeo.org
Thu Jan 24 11:10:41 PST 2013
 Reporter:  mlennert          |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  Vector            |     Version:  svn-trunk
 Keywords:  network distance  |    Platform:  Unspecified
      Cpu:  Unspecified       |
Comment(by mlennert):
 Replying to [comment:1 mmetz]:
 > Replying to [ticket:1861 mlennert]:
 > > When using v.net.distance in grass7, giving it all the available nodes
 as from and to nodes, the result is a series of zero length paths from
 each node to itself. v.net.distance should skip paths to self and chose
 the closest node amongst the remaining set of nodes.
 > Technically, this is possible and actually not very difficult, but it
 would require to rewrite v.net.distance from scratch.
 > Currently, the module starts with all 'to' nodes and calculates the
 shortest path of all nodes to all 'to' nodes. Then the module iterates
 through the 'from' nodes and finds for each 'from' node the nearest 'to'
 node. At this point it is too late to exclude paths to self because that
 is the only path computed.
 Ok, then I'll just add a hint to the man page indicating that from and to
 nodes should be different. One can always use v.net.allpairs to get the
 same info with a bit of postprocess data massaging.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1861#comment:2>
