[GRASS-dev] [GRASS GIS] #1863: DBMI Protocol Error in v.extract
trac at osgeo.org
Thu Jan 24 18:36:55 PST 2013
Reporter: dkavanagh | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: | Platform: MSWindows 7
Cpu: Unspecified |
I am getting a DBMI Protocol error in v.extract when I query a field value
that is equal to 10 (e.g. HCA_ID=10). The exact command is:
v.extract -t --overwrite input=cores type=area where=HCA_ID=10 output=core
If I filter for 9, 11, 20 or 100 the problem does not occur.
I opened the sqlite database directly and queried it. No errors occurred.
The field type is integer.
I originally encountered the problem when I ran the v.extract command in a
Python script. The script hangs and does not report an error. You have to
kill the sqlite exe to free the file lock.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1863>
