[GRASS-dev] g.extension not working on debian - grass 6.4.3svn
Margherita Di Leo
dileomargherita at gmail.com
Sat Jan 26 05:11:57 PST 2013
After having tested g.extension (svn-releasebranch64) with fresh
installation both on Debian and on Red Hat, both with default installation
and on local installation (bindir and prefix in /home/somewhere), FWIW, the
result is that the only way to make it work is to compile grass without
installing (make without make install).
madi
On Fri, Dec 7, 2012 at 1:31 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Dec 6, 2012 at 7:20 PM, Margherita Di Leo
> <dileomargherita at gmail.com> wrote:
> > Hi All,
> > I'm having issues in using g.extension and before filing a bug report I
> > should like to know whether am I not seeing anything obviously wrong
> from my
> > side.
> > GRASS 6.4.3svn (nc_spm_08):~ > g.extension extension=r.stream.extract
> > operation=add
> > /usr/local/grass-6.4.3svn/include/Make/Rules.make:99: warning: ignoring
> old
> > commands for target `install'
> > mkdir -p
> /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/man/man1
> > GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.3svn sh
> > /usr/local/grass-6.4.3svn/tools/g.html2man
> /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/docs/html/r.stream.extract.html
> /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/man/man1/r.stream.extract.1
> > 1
> > make[2]: ***
> [/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/man/man1/r.stream.extract.1]
> > Error 127
> > make[2]: Leaving directory
> `/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/r.stream.extract'
> > make[1]: *** [mancmd] Error 2
> > make[1]: Leaving directory
> > make: *** [cmd] Error 2
> > ERROR: Compilation failed, sorry. Please check above error messages.
> On Fedora no problem to install it. Only on Ubuntu it fails, always
> here
> g.html2man ...
> Someone with Ubuntu will need to analyze the (already known) problem....
> Markus
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130126/c2ae2bc7/attachment.html>
