[GRASS-dev] [GRASS GIS] #1864: r.horizon generates incorrect results in single point mode
GRASS GIS trac at osgeo.org
Sun Jan 27 06:44:42 PST 2013
 Reporter:  rmyorston  |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  6.4.3
Component:  Raster     |     Version:  6.4.2
 Keywords:             |    Platform:  Linux
      Cpu:  x86-32     |
 I wished to use r.horizon to calculate horizon values in single point
 mode. Initially I used a 50m DEM and the results looked reasonable. Later
 I obtained a 10m DEM for the region and performed the same calculation.
 The results were very different. When I used map mode with the 10m DEM the
 result for the chosen location and angle agreed with that of the 50m DEM.
 The problem seems to be in test_low_res, which is intended to switch to a
 low resolution grid at a certain point in the calculation. I've built
 r.horizon without the call to test_low_res (just setting succes2 to 1) and
 the results with the 10m DEM agree pretty well with those for the 50m one.
 In the code with the comment /*skip to the next lowres cell */ delta
 values for x and y are calculated. These depend on cosangle and sinangle.
 It appears that these aren't being set in single point mode, so both are
 zero. This results in mindel being 32000 and hence the point calculated is
 off the grid. In my case this stopped the horizon calculation after 2200m,
 far too early.
 I think there are other problems with test_low_res, but I didn't
 investigate further.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1864>
