[GRASS-dev] does GRASS 7 for Mac compile yet?
Anna Kratochvílová kratochanna at gmail.com
Thu Jan 31 08:37:45 PST 2013
On Thu, Jan 31, 2013 at 5:02 PM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> Anna,
> we just started to dig into this with Michael about two days ago. I believe the errors started to pop-up with the introduction
> of g.gui.* - all of these commands have it and at the time when g.gui.* was being added, the list of modules with this error
> has been expanding. The error messages below are from Michael, but I get exactly the same ones - see the error for mapswipe.
> Before g.gui was introduced, mapswipe did not produce an error. And this is on MacOSX10.6 and MacOSX10.8.
> BUT for me on 10.6, in spite of the error message, most of these modules actually run OK - I tried mapswipe, psmap,vdigit,
> and wxnviz and m.nviz.image run too. Perhaps others can test the rest of the modules.
> So it may be just a manual page or something like that.
> The only thing that does not run is animation - I will email about it separately because it may be a separate issue.
> Helena
> Errors in:
> /Users/Shared/grass_dev/grass70_dev/gui/wxpython/animation
> /Users/Shared/grass_dev/grass70_dev/gui/wxpython/mapswipe
> /Users/Shared/grass_dev/grass70_dev/gui/wxpython/gmodeler
> /Users/Shared/grass_dev/grass70_dev/gui/wxpython/rlisetup
> /Users/Shared/grass_dev/grass70_dev/gui/wxpython/psmap
> /Users/Shared/grass_dev/grass70_dev/gui/wxpython/dbmgr
> /Users/Shared/grass_dev/grass70_dev/gui/wxpython/vdigit
> /Users/Shared/grass_dev/grass70_dev/gui/wxpython/iclass
> for each of those I get the same error like this
> cmb-macbookpro:~ cmbarton$ /Users/Shared/grass_dev/grass70_dev/gui/wxpython/animation
> -bash: /Users/Shared/grass_dev/grass70_dev/gui/wxpython/animation: is a directory
> cmb-macbookpro:~ cmbarton$ cd /Users/Shared/grass_dev/grass70_dev/gui/wxpython/animation
> cmb-macbookpro:animation cmbarton$
> cmb-macbookpro:animation cmbarton$ make
> make /Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0/docs/html/g.gui.animation.html
> GISRC=/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0/demolocation/.grassrc70 GISBASE=/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0 PATH="/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0/bin:/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0/bin:$PATH" PYTHONPATH="/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0/etc/python:/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0/etc/python:$PYTHONPATH" DYLD_LIBRARY_PATH="/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0/bin:/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0/lib:/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0/lib:" LC_ALL=C /Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0/scripts/g.gui.animation --html-description < /dev/null | grep -v '</body>\|</html>' > g.gui.animation.tmp.html
> Traceback (most recent call last):
>  File "/Users/Shared/grass_dev/grass70_dev/dist.x86_64-apple-darwin12.2.0/scripts/g.gui.animation", line 45, in <module>
>    import wx
> ImportError: No module named wx
> make[1]: *** [g.gui.animation.tmp.html] Error 1
> rm g.gui.animation.tmp.html
> cpe-098-026-069-175:mapswipe helena$ make
> make /Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/docs/html/g.gui.mapswipe.html
> GISRC=/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/demolocation/.grassrc70 GISBASE=/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0 PATH="/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/bin:/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/bin:$PATH" PYTHONPATH="/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/etc/python:/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/etc/python:$PYTHONPATH" DYLD_LIBRARY_PATH="/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/bin:/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/lib:/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/lib:" LC_ALL=C /Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/scripts/g.gui.mapswipe --html-description < /dev/null | grep -v '</body>\|</html>' > g.gui.mapswipe.tmp.html
>   File "/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/scripts/g.gui.mapswipe", line 51, in <module>
>     import  wx
>   File "/var/tmp/wxWidgets/wxWidgets-13~231/2.6/DSTROOT/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/__init__.py", line 45, in <module>
>   File "/var/tmp/wxWidgets/wxWidgets-13~231/2.6/DSTROOT/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_core.py", line 4, in <module>
> ImportError: /System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_core_.so: no appropriate 64-bit architecture (see "man python" for running in 32-bit mode)
> make[1]: *** [g.gui.mapswipe.tmp.html] Error 1
> rm g.gui.mapswipe.tmp.html
> make: *** [guiscript] Error 2
Maybe this could be helpful [1]? Also, there is a changeset [2] which
could be related although it is quite old.
[1] http://stackoverflow.com/questions/2565201/wxpython-incompatible-with-snow-leopard
[2] http://trac.osgeo.org/grass/changeset/40523
> Helena Mitasova
> Associate Professor
> Department of Marine, Earth, and Atmospheric Sciences
> 2800 Faucette Drive, Rm. 1125 Jordan Hall
> North Carolina State University
> Raleigh, NC 27695-8208
> hmitaso at ncsu.edu
> "All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
> On Jan 31, 2013, at 6:15 AM, Anna Kratochvílová wrote:
>> On Thu, Jan 31, 2013 at 11:47 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>>> 2013/1/31 Thomas Adams - NOAA Federal <thomas.adams at noaa.gov>:
>>>> All,
>>> Hi Thomas
>>>> I'm a Mac user in addition to Linux. I'm going to have more free time
>>>> starting in a few weeks. I'd be happy to step-up my use of GRASS 7 for
>>>> testing. Just let me know what I can do. I'm moving from the U.S. to
>>>> Melbourne, Australia in a couple of weeks!
>>> thanks for your support, you could start to read from here [0].
>>> Michael and William could you update the instructions of this file [1]
>>> for GRASS7 and move them to the wiki page please?
>> Michael, it would be helpful to summarize all the problems. It is very
>> confusing at least for me. It is not clear which problems are related
>> to the introduction of g.gui.* modules, wxPython version and so on
>> because the information is in many threads.
>> Thanks,
>> Anna
>>>> Cheers,
>>>> Tom
>>> [0] http://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX
>>> [1] http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/macosx/ReadMe.rtf?format=raw
>>> ciao
>>> Luca
>>> http://gis.cri.fmach.it/delucchi/
>>> www.lucadelu.org
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
