[GRASS-dev] [GRASS GIS] #1719: GRASS 7 Monitor command line support
trac at osgeo.org
Mon Jul 1 18:14:14 PDT 2013
Reporter: annalisapg | Owner: grass-dev@…
Type: enhancement | Status: reopened
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: d.mon
Platform: Unspecified | Cpu: Unspecified
Comment(by nikosa):
Replying to [comment:22 hamish]:
> wish: for 'd.mon wx0' be able to turn off the toolbar and replace it a
right-click context menu. a menu item there to also turn on/off the lower
status bar.
Yes, please :-). I know, I cannot code this stuff... can I do, however,
anything else to support this cause?
> right now those are avoided with grass-
addons/grass7/display/d.mon2/d.mon2.py, but it's not an ideal solution.
Can't draw anything in d.mon2 currently (rev.=56960) :-?
> Since this is near to the original wish & mentioned early in it,
g.region is not respected upon d.redraw, and the redraw speed is still too
slow, I'm reopening instead of creating a new ticket saying the same
things.
Same experiences here using G7 the last months. When I learned about
ximgview (via the ML) I was really happy just because of the speed
difference! And, yes, launching "d.mon wx0" moves the CPUs a bit up.
Otherwise, the wx monitor(s) are great -- all of the pan, d.zoom, g.region
and d.histogram operations at your fingertips.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1719#comment:24>
