[GRASS-dev] [GRASS GIS] #2019: v.voronoi Segmentation fault
trac at osgeo.org
Mon Jul 1 23:31:56 PDT 2013
Reporter: DmitryKolesov | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version:
Keywords: v.voronoi | Platform: Unspecified
Cpu: Unspecified |
Comment(by DmitryKolesov):
Replying to [comment:1 hamish]:
> is it trying to make a triangle (with area==0) from two points? or were
those two points extracted from a larger map having the problem?
Yes, I tryed to create Voronoi diagram from 2 points. But I think
(probably wrong):
1) Voronoi diagram of 2 points is possible (the line splits the plain in
two half-planes)
2) In any case the module should print a message (the module crashes now).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2019#comment:3>
