[GRASS-dev] [GRASS GIS] #2020: r.volume gives wrong results on G7
trac at osgeo.org
Tue Jul 2 08:04:55 PDT 2013
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.volume | Platform: Linux
Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:3 hamish]:
> The problem is with the handling NULL cells in the input map, or rather
not handling them. It's this line in main.c: `sum[i] += data_buf[col];`
> Every now and then the value which is added is -2147483648 instead of in
the range of ~ 0-36. That happens when the clump map exists but the input
map does not. So for your test data the slope map is 1 cell smaller than
the basins map around the edges of the area, and those cells which are
non-NULL in the basins map but NULL in the slope map return corrupted
values.
> fwiw between devbr6 and trunk there don't seem to be any module changes
beyond the conversion of G_() to Rast_() in the function names.
> I notice even in grass7 it's still trying to make an old grass5
sites_list points map, and also that the input map is always opened and
read as a CELL map, even when it is floating point, so the results will
be.. less correct than they might otherwise be due to
rounding/quantization errors. For 0.0-1.0 normalized data that might be
fatal. (conversion of the input to int(map*1000) with r.mapcalc gives the
same error for NULLs in 'sum' though)
NULL handling fixed and fp support added to r.volume in trunk r56984.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/2020#comment:4>
