[GRASS-dev] GRASS 6.4.3 release planning
Anna Petrášová
kratochanna at gmail.com
Tue Jul 2 11:57:08 PDT 2013
On Fri, Jun 28, 2013 at 2:29 AM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> regarding the r.mapcalc issue in command console on wingrass -
> (sorry I did not make it clear it was for wingrass - it always worked well
> on Mac and linux)
> It is not critical, windows users can still use the mapcalculator GUI
> where it runs OK,
> but the r.mapcalc in the command console still does not seem to work -
> tried by a student
> using June 26 snapshot this is what she says:
> Here are examples of the commands run and the errors received:
> r.mapcalc urban2_30m=if(landuse96_28m==1 ||
> landuse96_28m==2,landuse96_28m,null())
> syntax error, unexpected $end, expecting ')'
> Parse error
> 'landuse96_28m' is not recognized as an internal or external
> command,
> operable program or batch file.
> r.mapcalc MASK=if((elevation<100 && elevation>60) && (landuse96_28m==1 ||
> landuse96_28m==2),1,null())
> 1 was unexpected at this time.
> This is the same we were getting in GRASS6.4.3RC2 and apparently the
> proposed solutions did not work
> http://lists.osgeo.org/pipermail/grass-dev/2013-February/062047.html
> http://lists.osgeo.org/pipermail/grass-dev/2013-March/062607.html
I had the opportunity to test Glynn's patch (the second link above) on
Windows and it seems to solve the problems. From the discussion I can see
that Markus already tested it but he was not successful, so I applied the
patch to 6.5 first.
All the commands causing problems are now working with both (", ') quotes
and without, only the command with || requires quotes.
Anna
> if I get this confirmed I will file a bug report (I thought I already did,
> but it is not there).
> If it is not fixable it should be at least mentioned on the known issues
> web page
> http://grasswiki.osgeo.org/wiki/WinGRASS_Current_Status#Raster_modules
> Helena
> > Helena:
> >> I am also wondering whether the r.mapcalc expressions with || (or)
> >> now run from the wxGUI command console.
> > I just tried on linux 6.4.3svn wxGUI command console:
> > r.mapcalc "either = 0 || 1"
> > and it worked.
> > In general I wouldn't be surprised if full command line quoting took
> > years and huge amounts of effort to (re)perfect. And even then, does
> > it try to follow Bash conventions, or python, or DOS, or some mix of
> > all those? How much do we try to (re)teach about command line
> > techniques in our own docs? Will unquoted input=C:\Users\files\data.txt
> > always be parsed to input=C:Usersfilesdata.txt (literal \U, \f, \d)
> > in the command console in that case?
> > best,
> > Hamish
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130702/2aefca30/attachment-0001.html>
