[GRASS-dev] [GRASS GIS] #2020: r.volume gives wrong results on G7
GRASS GIS trac at osgeo.org
Tue Jul 2 14:47:51 PDT 2013
 Reporter:  madi      |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Raster    |     Version:  svn-trunk
 Keywords:  r.volume  |    Platform:  Linux
      Cpu:  x86-64    |
Comment(by mmetz):
 Replying to [comment:7 hamish]:
 > > You can now file a bug for r.volume in G6.
 > we may as well continue with this ticket since it isn't too complicated.
 Is it ok to open a CELL map as DCELL in grass6, or do we need a switch
 statement to use the correct read/isnull commands?
 I think it is ok to open CELL or FCELL maps as DCELL in grass6, IIRC
 various modules do so already.
 > if skipping adding to sum because of a null, don't we need to 'count--'
 too? or else for the average sum/n has too big an n.
 Right, fixed in r56987.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2020#comment:8>
