[GRASS-dev] [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS installer distribution
GRASS GIS trac at osgeo.org
Wed Jul 3 17:05:19 PDT 2013
 Reporter:  ddalimonte                 |       Owner:  hamish
     Type:  defect                     |      Status:  new
 Priority:  major                      |   Milestone:  6.4.4
Component:  Projections/Datums         |     Version:  svn-releasebranch64
 Keywords:  r.in.wms, wingrass, cs2cs  |    Platform:  MSWindows XP
      Cpu:  All                        |
Comment(by hamish):
 re. cs2cs + grid paths, it is still a problem with the latest nightly
 build.
 if you are on wingrass and using grass 6.x and using a datum transform
 grid file in your projection definition, m.proj fails. (and so r.in.wms.sh
 too)
 two issues:
 - the path to the +nadgrids file should be quoted (see proj4 ticket # 218)
 - msys is messing up the path string (the "g.message '/'" expansion
 problem).
 possible aid for the second issue in init.sh and r.in.wms.sh's wms_request
 with "dos2unix_path()", but I don't know if that helps here or not until
 the quoting issue gets fixed.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:51>
