[GRASS-dev] i.segment on panchromatic band of Worldview 2 scene: what resources are necessary to complete segmentation ?
Moritz Lennert
mlennert at club.worldonline.be
Thu Jul 4 01:40:36 PDT 2013
Hello,
In parallel to the discussion going on in another thread, I have a
question concering the segmentation of another Worldview 2 scene:
I first used all 8 multispectral bands and managed to get a series of
results with increasing thresholds in very reasonable running times. The
region was as follows:
> g.region -p
projection: 1 (UTM)
zone: -36
datum: wgs84
ellipsoid: wgs84
north: 7251172
south: 7234772
west: 333792
east: 350192
nsres: 2
ewres: 2
rows: 8200
cols: 8200
cells: 67240000
and the command line:
i.segment group=xs out=seg_xs minsize=2 memory=3072 threshold=0.05 (and
thresh=0.1 and 0.2 in successive runs using the results of the previous
run as seeds).
Now, I would like to test segmentation of just the panchromatic band.
This means the following region settings:
projection: 1 (UTM)
zone: -36
datum: wgs84
ellipsoid: wgs84
north: 7251172
south: 7234772
west: 333792
east: 350192
nsres: 0.5
ewres: 0.5
rows: 32800
cols: 32800
cells: 1075840000
Trying to run with the following command line on my i3, 8GB RAM machine:
i.segment group=pan out=seg_pan_005 threshold=0.05 memory=3072
had the process running for almost 13 hours with it then becoming
apparently stuck in the fourth pass at 10%. At that point the percent
didn't change for over an hour, so I decided to kill the process. Can I
assume that I'm here above the capacities of my machine ? Is there
anything (besides working on a smaller subsample of the image) that I
can do to make it work ? What kind of resources would I need to be able
to run such a segmentation?
I guess I'll have to move these kinds of treatments to our university
supercomputer, but I first have to get them to install GRASS...
Moritz
