[GRASS-dev] GRASS 7: d.vect layer-option not allways recognised in wxGUI
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Thu Jul 4 02:45:16 PDT 2013
Hi
In GRASS 7 in the d.vect GUI the layer option is only recognised if typed in manually (not from the dropdown-list). When changing to other tabs, it is lost again. The result is that the layer is not displayed when where option is used.
I am working on Ubuntu 12.04 LTS 64bit.
Anyone who can confirm?
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130704/9838ca1e/attachment.html>
