[GRASS-dev] wingrass7 nightly builds broken
Martin Landa
landa.martin at gmail.com
Thu Jul 4 08:24:45 PDT 2013
2013/7/4 Martin Landa <landa.martin at gmail.com>:
>>>> I guess some osgeo4w update moved or removed regex?
>>> AFAICT no. apps/msys/include/regex.h is in still in msys-1.0.11-13 (and
>>> that's from Apr 13th).
>> Then it seems to be a problem on the server creating the nightly
>> builds. Actually it affects all branches.
> hm, there must be some change in osgeo4w framework. Last build is
> three days old. I will try to fix it ASAP.
should be OK now. I found out problem on the server side. When I was
working on the new version of msys package I have installed mingw
which caused this problem.
Sorry for inconvenience, Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
