[GRASS-dev] v.in.ogr fails to import from PostGIS with schema
Markus Metz markus.metz.giswork at gmail.com
Fri Jul 5 03:53:49 PDT 2013
On Fri, Jul 5, 2013 at 11:25 AM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Thanks Markus!
> It works now.
OK, backported to 6.5 and 6.4 in r57017/8.
> Regarding the status message: I just found it a bit confusing, not more than that...
Changed in trunk to
"Check if OGR layer <n50_2013_utm33n.n50_2013_arealdekke_lines>
contains polygons..."
Markus M
> Stefan
> -----Original Message-----
> From: Markus Metz [mailto:markus.metz.giswork at gmail.com]
> Sent: 5. juli 2013 10:51
> To: Blumentrath, Stefan
> Cc: grass-dev at lists.osgeo.org
> Subject: Re: [GRASS-dev] v.in.ogr fails to import from PostGIS with schema
> On Fri, Jul 5, 2013 at 10:02 AM, Blumentrath, Stefan <Stefan.Blumentrath at nina.no> wrote:
>> Dear all
>> I am reposting this message, because the problem, that I cannot import
>> lines from PostGIS is still present in GRASS 7 svn-revision 57009 (and in 6.4.3svn (older revision) too.) Do you think this is only due to my PostGIS og GDAL/OGR installation, or shall I file a ticket?
> Please try trunk r57016. If this works for you, the changes should be backported.
>> Another (much less important) thing here is, that the status message says:
>> "Counting polygons for 6125184 features (OGR layer
>> <n50_2013_utm33n.n50_2013_arealdekke_lines>)..."
>> although the layer only contains (6125184) lines...
> The module only knows if a layer only contains lines after it went through all features. In this case the polygon count will be zero.
> Unless you use v.in.ogr type=boundary in which case lines will be converted to boundaries.
> Markus M
>> Cheers
>> Stefan
>> From: grass-dev-bounces at lists.osgeo.org
>> [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Blumentrath,
>> Stefan
>> Sent: 31. mai 2013 08:27
>> To: Markus Neteler; grass-dev at lists.osgeo.org
>> schema
>> Hi Markus
>> Sorry, good to know. It was HTML indeed.
>> So here is the problem-description in plain ASCII:
>> When I try to import a vector map containing (lots of) lines from a certain schema in a PostGIS-database, i get the following error messages:
>>  v.in.ogr dsn="PG:host=myserver dbname=gisdata" layer="n50_2013_utm33n.n50_2013_arealdekke_lines" output="Test"
>> DBMI-SQLite driver error:
>> Error in sqlite3_prepare():
>> unrecognized token: "3insert"
>> ERROR: Cannot insert new row: insert into Test values ( 3insert into Test
>>        values ( 3, NULL, NULL, NULL, NULL, NULL, NULL, 'FiktivDelelinje',
>>        '1000-01-01 0:00:00', NULL, 101 )
>>  While other formats with the same data work just fine:
>> ogr2ogr -f SQLite /home/stefan/tmp/N50/n50_2013_arealdekke_lin.sqlite
>> v.in.ogr dsn=/home/stefan/tmp/N50/n50_2013_arealdekke_lin.sqlite output="N50_2013_arealdekke_lin"This gave no errors...
>> Forgot to mention in my earlier post, that also importing polygons from the same PostGIS database (and schema) as the lines works fine:
>> v.in.ogr dsn="PG:host=myserver dbname=gisdata" layer="n50_2013_utm33n.n50_2013_arealdekke_polygons" output="Test_pol"
>> Gave no error messages either...
>> So, maybe it is something with the geometry type?
>> Cheers
>> Stefan
>> From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On
>> Behalf Of Markus Neteler
>> Sent: 31. mai 2013 00:22
>> schema
>> Hi Stefan,
>> you message (HTML?) did not contain the relevant error... see below.
>> It is better to send in pure ASCII...
>> Best
>> Markus
>> On Thu, May 30, 2013 at 9:51 PM, SBL <Stefan.Blumentrath at nina.no> wrote:
>>> Hi
>>> When I try to to import a vector map containing (lots of) lines from
>>> I was using GRASS 7 (compiled about a month ago) and PostGIS 2.0.1 /
>>> PostgreSQL 9.1 on Ubuntu 12.04 LTS Server.
>>> Looks like something got mixed up in the insert statement. Is that a
>>> known issue or shall I file a ticket?
>>> Cheers
>>> Stefan
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/v-in-ogr-fails-to-import-from-Pos
>>> t GIS-with-schema-tp5057034.html Sent from the Grass - Dev mailing
>>> list archive at Nabble.com.
>>> grass-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
