[GRASS-dev] Compiling grass7_trunk in Funtoo
Nikos Alexandris nik at nikosalexandris.net
Sun Jul 7 01:25:21 PDT 2013
Hi devs!
Hope that some advanced Gentoo user is tuned-in.  I am trying to compile
grass7_trunk in Funtoo.  I managed to get a clean configuration of almost
everything required (except for LAPACK, BLAS and FFMPEG, all of which, if
I am no miss-taking, are not required).
The compilation ends-up like:
Started compilation: Sun Jul  7 10:24:41 EEST 2013
Errors in:
/osgeo/src/grass7_trunk/lib/python/ctypes
/osgeo/src/grass7_trunk/db/drivers/ogr
/osgeo/src/grass7_trunk/db/drivers/dbf
/osgeo/src/grass7_trunk/db/drivers/postgres
/osgeo/src/grass7_trunk/db/drivers/sqlite
/osgeo/src/grass7_trunk/db/drivers/odbc
/osgeo/src/grass7_trunk/db/drivers/mysql
/osgeo/src/grass7_trunk/gui/wxpython/vdigit
/osgeo/src/grass7_trunk/gui/wxpython/mapswipe
/osgeo/src/grass7_trunk/gui/wxpython/rlisetup
/osgeo/src/grass7_trunk/gui/wxpython/animation
/osgeo/src/grass7_trunk/gui/wxpython/dbmgr
/osgeo/src/grass7_trunk/gui/wxpython/psmap
/osgeo/src/grass7_trunk/gui/wxpython/iclass
/osgeo/src/grass7_trunk/gui/wxpython/gmodeler
/osgeo/src/grass7_trunk/man
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Sun Jul  7 10:25:27 EEST 2013
make: *** [default] Error 1
Running make inside some of the above mentioned directories, tells that
some script was denied permissions to execute.  I think it is a
Gentoo/Funtoo thing and has nothing to do with GRASS or missing
dependencies.
For example,
/osgeo/src/grass7_trunk/db/drivers/ogr $ make
VERSION_NUMBER=7.0.svn /osgeo/src/grass7_trunk/dist.x86_64-unknown-
linux-gnu/tools/g.html2man.py /osgeo/src/grass7_trunk/dist.x86_64-
unknown-linux-gnu/docs/html/grass-ogr.html
/osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
gnu/docs/man/man1/grass-ogr.1
/bin/sh: /osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
gnu/tools/g.html2man.py: Permission denied
make: *** [/osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
gnu/docs/man/man1/grass-ogr.1] Error 126
or
nik at localhost /osgeo/src/grass7_trunk/gui/wxpython/vdigit $ make
gnu/scripts/g.gui.vdigit: Permission denied
make[1]: *** [g.gui.vdigit.tmp.html] Error 1
rm g.gui.vdigit.tmp.html
make[1]: Leaving directory `/osgeo/src/grass7_trunk/gui/wxpython/vdigit'
make: *** [guiscript] Error 2
What should I watch out for?
Thank you, Nikos
