[GRASS-dev] Compiling grass7_trunk in Funtoo
Nikos Alexandris
nik at nikosalexandris.net
Sun Jul 7 02:34:43 PDT 2013
Nikos Alexandris:
> > Hope that some advanced Gentoo user is tuned-in. I am trying to compile
> > grass7_trunk in Funtoo. I managed to get a clean configuration of almost
> > everything required (except for LAPACK, BLAS and FFMPEG, all of which, if
> > I am no miss-taking, are not required).
Markus Metz wrote:
> You can check for optional functionality with ./configure --help.
> AFAIK, BLAS and LAPACK are not used.
> > The compilation ends-up like:
> > Started compilation: Sun Jul 7 10:24:41 EEST 2013
> > Errors in:
> > /osgeo/src/grass7_trunk/lib/python/ctypes
> > /osgeo/src/grass7_trunk/db/drivers/ogr
> > /osgeo/src/grass7_trunk/db/drivers/dbf
> > /osgeo/src/grass7_trunk/db/drivers/postgres
> > /osgeo/src/grass7_trunk/db/drivers/sqlite
> > /osgeo/src/grass7_trunk/db/drivers/odbc
> > /osgeo/src/grass7_trunk/db/drivers/mysql
> > /osgeo/src/grass7_trunk/gui/wxpython/vdigit
> > /osgeo/src/grass7_trunk/gui/wxpython/mapswipe
> > /osgeo/src/grass7_trunk/gui/wxpython/rlisetup
> > /osgeo/src/grass7_trunk/gui/wxpython/animation
> > /osgeo/src/grass7_trunk/gui/wxpython/dbmgr
> > /osgeo/src/grass7_trunk/gui/wxpython/psmap
> > /osgeo/src/grass7_trunk/gui/wxpython/iclass
> > /osgeo/src/grass7_trunk/gui/wxpython/gmodeler
> > /osgeo/src/grass7_trunk/man
> > In case of errors please change into the directory with error and run
> > 'make'.
> Please note that...
> > If you get multiple errors, you need to deal with them in the order they
> > appear in the error log. If you get an error building a library, you will
> > also get errors from anything which uses the library.
> > Finished compilation: Sun Jul 7 10:25:27 EEST 2013
> > make: *** [default] Error 1
> > Running make inside some of the above mentioned directories,
> You should really start with the first error
So did I. Sorry, I skipped it in my post. The first error is:
/bin/sh: ./ctypesgen.py: Permission denied
make[1]: *** [OBJ.x86_64-unknown-linux-gnu/date.py] Error 126
make[1]: Leaving directory `/osgeo/src/grass7_trunk/lib/python/ctypes'
make: *** [default] Error 2
> > tells that
> > some script was denied permissions to execute. I think it is a
> > Gentoo/Funtoo thing and has nothing to do with GRASS or missing
> > dependencies.
More upon this -- The partition I am running all this is mounted as
/dev/sda5 /osgeo ext4 auto,rw,exec,user 0 2
Trying in fist place to execute "./confiure" or "./configure --help"
wouldn't/wont do a thing. i.e.
./configure --help
bash: ./configure: Permission denied
Instructing, as I read somewhere (don't remember where!), "sh ./configure --
help" works fine! So, I think it is the same issue here too. For example,
./osgeo/src/grass7_trunk/lib/python/ctypes $ ./ctypesgen.py
bash: ./ctypesgen.py: Permission denied
So, in a similar way, instructing
python ./ctypesgen.py
Error: No header files specified
seems to work just fine.
My guess is that it's the same for all "Permission denied" errors. I need to
find a "global" solution and not going into handcrafting the scripts myself --
that wouldn't be the "right" way to do it.
> > For example,
> > /osgeo/src/grass7_trunk/db/drivers/ogr $ make
> > VERSION_NUMBER=7.0.svn /osgeo/src/grass7_trunk/dist.x86_64-unknown-
> > linux-gnu/tools/g.html2man.py /osgeo/src/grass7_trunk/dist.x86_64-
> > unknown-linux-gnu/docs/html/grass-ogr.html
> > /osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
> > gnu/docs/man/man1/grass-ogr.1
> > /bin/sh: /osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
> > gnu/tools/g.html2man.py: Permission denied
> Check the permissions of
> /osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-gnu/tools/g.html2man.py
ls -lah g.html2man.py
-rwxr-xr-x 1 nik users 1.1K Jul 7 10:24 g.html2man.py
and "I" am in users,
groups nik
wheel audio cdrom video users
Hence, if I do
python /osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
File "/osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
gnu/tools/g.html2man.py", line 48, in <module>
main()
gnu/tools/g.html2man.py", line 15, in main
infile = sys.argv[1]
IndexError: list index out of range
it looks like it's going.
[stuff remove]
> Compilation should be done as normal user, not root. That means that
> the source should be obtained and copied to its current location as
> normal user. Maybe that helps.
Yes, I don't repeat this (anymore, since long ago). Trying to learn
Gentoo/Funtoo :-)
Danke Markus,
Nikos
