[GRASS-dev] i.segment on panchromatic band of Worldview 2 scene: what resources are necessary to complete segmentation ?
Yann Chemin
ychemin at gmail.com
Sun Jul 7 02:52:20 PDT 2013
1 - Find a faster CPU machine with 16Gb RAM and a SSD for a start, it
will be better,
Also if you have the opportunity check that the RAM is a 1800MHz one,
details like this may actually add your computation performance.
2 - Cut in pieces (See Markus Comment about supercomputing) and run 4
quads on 4 CPUs instead of one large image in one CPU.
3 - Recode i.segment to work natively on heterogeneous computers...
(would be fun!)
Good luck!
On 4 July 2013 14:10, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> Hello,
> In parallel to the discussion going on in another thread, I have a question
> concering the segmentation of another Worldview 2 scene:
> I first used all 8 multispectral bands and managed to get a series of
> results with increasing thresholds in very reasonable running times. The
> region was as follows:
>> g.region -p
> projection: 1 (UTM)
> zone: -36
> datum: wgs84
> ellipsoid: wgs84
> north: 7251172
> south: 7234772
> west: 333792
> east: 350192
> nsres: 2
> ewres: 2
> rows: 8200
> cols: 8200
> cells: 67240000
> and the command line:
> i.segment group=xs out=seg_xs minsize=2 memory=3072 threshold=0.05 (and
> thresh=0.1 and 0.2 in successive runs using the results of the previous run
> as seeds).
> Now, I would like to test segmentation of just the panchromatic band. This
> means the following region settings:
> projection: 1 (UTM)
> zone: -36
> datum: wgs84
> ellipsoid: wgs84
> north: 7251172
> south: 7234772
> west: 333792
> east: 350192
> nsres: 0.5
> ewres: 0.5
> rows: 32800
> cols: 32800
> cells: 1075840000
> Trying to run with the following command line on my i3, 8GB RAM machine:
> i.segment group=pan out=seg_pan_005 threshold=0.05 memory=3072
> had the process running for almost 13 hours with it then becoming apparently
> stuck in the fourth pass at 10%. At that point the percent didn't change for
> over an hour, so I decided to kill the process. Can I assume that I'm here
> above the capacities of my machine ? Is there anything (besides working on a
> smaller subsample of the image) that I can do to make it work ? What kind of
> resources would I need to be able to run such a segmentation?
> I guess I'll have to move these kinds of treatments to our university
> supercomputer, but I first have to get them to install GRASS...
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
