[GRASS-dev] [GRASS GIS] #2010: r.in.wms2 fails to install on 6.x
trac at osgeo.org
Mon Jul 8 06:09:37 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.4
Component: Addons | Version: svn-releasebranch64
Keywords: r.in.wms2 | Platform: Linux
Cpu: All |
Comment(by turek):
Replying to [comment:7 hamish]:
> * png8 support missing for WMS 1.3.0
In capabilties file of WMS 1.1.1 there are two formats: image/png;
mode=8bit and image/png8. In WMS 1.3.0 there is only image/png; mode=8bit
format. I am not sure which one to use. Currently is used image/png8
therefore you can not see png8 in WMS 1.3.0. Maybe it should be used
image/png; mode=8bit, because WMS 1.3.0 is more restrictive regarding
formats. It requires only MIME types formats. WMS 1.1.1. is more
benevolent. It could mean that image/png; mode=8bit is MIME type and the
other is not. Or it just changes randomly from server to server?
> * color picker greyed out in the "Add web service layer" WMS gui.
That is not very user friendly. If you check do not request transparent
data, the button will be activated. Should be the tooltip added there or
the button should be hidden if the choice is not checked? Or just let it
activated also when it is unchecked?
> * loss of region precision in the saved map,
Probably it is caused by reprojection (using gdalwarp).
> * WFS mixes in WMS layers, and has lot of traceback parse errors, but
realistic data plots; can't query it in the map display window though. is
WFS supposed to work yet or is it still a work in progress?
WFS is not supported, parser just tries interpret capabilities file
somehow. The parser is written in tolerant way, so it does not enforce
standards strictly, instead of this it tries to interpret everything what
it can understood.
Best
Stepan
Ticket URL: <https://trac.osgeo.org/grass/ticket/2010#comment:8>
