[GRASS-dev] GRASS 7: d.vect layer-option not allways recognised in wxGUI
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Wed Jul 10 03:05:21 PDT 2013
>>>>Stefan wrote:
>>>> In GRASS 7 in the d.vect GUI the layer option is only recognised if
>>>> typed in manually (not from the dropdown- list). When changing to
>>>> other tabs, it is lost again.
>>>> The result is that the layer is not displayed when where option is
>>>> used.
>>>> I am working on Ubuntu 12.04 LTS 64bit.
>>>>Anyone who can confirm?
>>>sounds related:  https://trac.osgeo.org/grass/ticket/2012
>For the record: the issue has been fixed and the ticket closed.
>Hope you agree :)
>Markus
Yes, agreed.
Stefan
