[GRASS-dev] [GRASS GIS] #2030: wxgui doesn't allow to query invisible map layers
GRASS GIS trac at osgeo.org
Wed Jul 10 09:44:13 PDT 2013
  Reporter:  marisn       |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  minor        |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by marisn):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:1 annakrat]:
 > It was intended behavior so the fix is easy (r57057) but I agree new
 bahavior makes sense.
 As most of (all?) GIS programs allow to query any layer despite it's
 visibility status, it makes sense to keep as is.
 Note - ArcGIS and QGIS both allow to choose "query only visible layers" as
 an option but default usually is "query all/active". If such behaviour is
 wanted, it should be opt-in, like in other GIS packages.
 Thanks for fix. Closing it as various query options should be a separate
 enhancement.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2030#comment:2>
